Hello
I am creating an android app using Cordova, I am using the following plugin (https://github.com/r-kitek/cordova-team-viewer) to create a team viewer session for support staff to view and access the app remotely. I followed all the documentation on https://integrate.teamviewer.com/en/develop/screen-sharing-sdk/android-tutorial/ page and generated the SDK Token and Configuration ID. But when I try to create the session using TVSessionFactory.createTVSession using my SDK Token it gives me an "INTERNAL_ERROR".
Other SDK methods like building the "TVSessionConfiguration" works completely fine.
The Android version on my device is 4.2.2 which is higher than the supported version by Android SDK.
Thank you for any help.
