I am trying to run ADsync script and getting this error.
AD read failed! The error was 'Logon failure: unknown user name or bad password
What password and user is it talking about ?
Hi dkhakhlou,
This is not possible at the moment but you can create a featue request under "ideas" for this
Cheers,
I see what the password is right now. Is there any way Teamviewer does password sync as well ?
Which password should i put in the init. password field ?
Do you know our new feature the "AD Connector"?
https://community.teamviewer.com/t5/Knowledge-Base/AD-Connector/ta-p/31158
Please try it with the new AD Connector
See what's new at TeamViewer
