Hello...
Recently I noticed a very serious problem with your application that modifies the system settings without the user's knowledge. A simple matter, just connect to a meeting or remote control, and the application changes the microphone settings in Windows without the user's knowledge, which means, for example, I can not normally use a lower application for the TeamSpeak communicator and other applications that use the microphone.
What the **bleep** are you doing with your application ... What law does it modify the microphone parameters in the system ??????????? !!!!!!!!!!!!!!!
This is not really serious .... The newer the updates, the worse the application.
And the last thing ... How do you treat people with the "Free" license status, that they can not write a normal technical application, and press the story that "Due to the large number of submissions, we were forced to serve only those with a license - mockery! !!!!!!!!!!!!!!!!!!!!!!!!!
