Hello Togehter,
I have a problem with the last meeting.I had a disconect and could not dial into the meeting anymore, after every PC restart I get the message that meeting has already expired.How can I delete this message?
with best regards
Good Morning @Sorodon,
Thank you for getting back to us.
What you describe in your post is an expected behavior when the meeting was setup in the scheduler and is no longer available. For this reason we regret to inform you that we cannot assist you further on this. We kindly ask you to contact the organizer so that he can create a new Meeting ID.
Enjoy your Wednesday!
Jaquie
Sorry for the late reply, i have already tryed to reinstall but it doesnt help.Is there a way to delete this message without conntact the creator.
Maybe a config-file ?
With best regards
Dear @Sorodon,
According to the described error message, it seems like the organizer has ended the meeting.
If this is not the case, it is very likely that the meeting ID that you have took place already (It was set up in the scheduler) and for this reason it is no longer available.
Please ask the organizer to schedule a new meeting so that the meeting ID changes and check if you are the only participant seeing this error message. If this is the case we strongly recommend that you re-install the software.
Cheers and have a nice Monday.
