Since version 13 (and maybe 12, not sure), I have noticed that when I connect to a device inside my subnet (by double clicking on the entry), Teamviewer is not using LAN connection. Which makes that connection slower and makes transfer files very much slower as it is going through internet.
However, if I enter the IP or computer name of that same device, it uses LAN.
Is there a way to make Teamviewer use by default the LAN if I'm on the same subnet of my computers ?
