Detected installations: 2 Remaining moves: 9
Im trying to remove a device from the web interface and I get the following error.
License activation failed. The provided ID is unknown.
Hello testuser,
Thank you for your reply.
I'm glad you could solve your problem.
Don't hesistate to re-post questions, if you encounter problems again.
Cheers,
I just installed the license on another computer and the old ones disappeared from the UI.
Hello dear Testuser,
I would recommend you to log out, and to try again with an other browser.
I hope this could help you out.
