Is there a way to deploy TeamViewer with LAN exclusively and password with registry setting ? Right now I've tried MSI and EXE host install and none uses my registry setting during the install (not done via GPO but locally).
I've used BAT file, Powershell script, tried via powershell command and CMD, both with admin right and not, all files are in the same folder (c:\temp for now). What ever I've tried the registry setting are never used. Is there something that i've missed that I need to do before ? I've read the official documentation (which is not up to date because you do not get a MSI package for deploy but an EXE, renaming the MSI doesn't uses my branding). I've read about 20 differents websites trying to figure this out to no avail.
Is it possible to install TV with registry setting or not ?
