Possible ISP block
JohnnyKing94
For quite a while I can no longer connect to any remote devices from my computer. I get this message "Not ready. Please check your connection" and the log file shows this:
LOG content removed
I think I've tried everything:
- Uninstalling teamviewer
- Restarting the service from the Services panel on Windows 10
- Disabled my personal antivirus (Bitdefender Total Security)
- Disabled Windows Firewall
- Flushed the DNS via cmd with "ipconfig /flushdns"
I can't even use my android tabled and phone with Teamviewer under my home network, but if I start using the 4G data network, everything is OK. I'm starting to consider it's an ISP related problem. I live in Italy and I have Telecom (also called TIM, the new brand name). Any idea?
1
ISP especially business routers block team viewer
login page is not accessible
you have to have a session ID I think
