Device Status issues
We have just started using this part of TeamViewer. We have about 100+ computers attached, so doing things one by one isn't our preferred option. A few things that are annoying and we'd like to see if we can change.
1/ The notifications show up for ALL computers we have the ability to connect to, not just the ones we set monitoring set up on. Can we turn this off, so only notifications show for machines we actively set monitoring on? This seems overkill in our situation.
None of the alerts on this screenshot are set by us.
2/ Can these notification types be customised? We really don't care about whether the computers have firewall activated or not, so we'd rather not show these.
3/ Can we make these notifications fully go away once acknowledged? It seems it just changes the flag, as per the top entry in the picture.
JoshP Posts: 398 Senior Moderator
Hello all,
Thank you for your posts.
The TeamViewer community is a user-driven community - most answers and solutions come from other users like yourself; we cannot guarantee an employee can see and respond to all posts here.
Regarding the issue posted, I would refer you to our Knowledgebase, where we have a support article pertaining to these alerts and how to remove them; click the following link to learn how to disable such alerts.
How can I disable the alert messages in my Computers & Contacts list?
Hope this helps!
Senior Community Moderator5
Really annoying,, Teamviewer wont answer on this one because probably cant turn it off !!
