When I setup Teamviewer on my Ubuntu 16.04 for the first time, I got problem. It always tell me incorrect password even the password is correct. I setup password in option, still same. and it's making random errors, slow to connect, and denied connection.
Then I decided to clean install Ubuntu 16.04. TeamViewer worked perfectly for a while. Now all of sudden the problem come back with 3 random errors, Incorrect password, slow to connect, and connection denied.
I can remote my Windows computer from Ubuntu just fine, not remoting Ubuntu computer with Windows computer
I don't understand why
Here is log
2019/01/14 09:40:06.172 10608 7020 G1 PrinterDriverInstaller::IsInstalled: result = 0
2019/01/14 09:31:26.422 10608 7020 H32 Loader: SharedMem Connected (seg = 0x9ae0000, refcnt = 1)
2019/01/14 09:31:26.422 10608 7020 H32 teamviewer.exe: SharedMem Connected (seg = 0x9ae0000, refcnt = 2)
2019/01/14 09:31:26.472 428 3808 H32 Loader: SharedMem Connected (seg = 0x6a0000, refcnt = 1)
2019/01/14 09:31:26.472 428 3808 H32 tv_w32.exe: SharedMem Connected (seg = 0x6a0000, refcnt = 2)
2019/01/14 09:31:26.478 9376 11844 H64 Loader: SharedMem Connected (seg = 0x96a70000, refcnt = 1)
2019/01/14 09:31:26.478 9376 11844 H64 tv_x64.exe: SharedMem Connected (seg = 0x96a70000, refcnt = 2)
2019/01/14 09:31:26.636 10608 7020 H32 teamviewer.exe: SharedMem_SetLogLevel: 0 -> 200
2019/01/14 09:40:07.386 10608 7020 G1 Trying connection to xxxxxxxxxx, mode = 1
2019/01/14 09:40:07.401 10608 7780 G1 Activating Router carrier
2019/01/14 09:40:07.401 10608 7780 G1 CProcessCommandHandlerMasterConnect[8]::CreateMasterConnect(): master5.teamviewer.com:5938, Connection 11, proxy=''
2019/01/14 09:40:07.440 10608 6856 G1 CProcessCommandHandlerMasterConnect[8]::HandleMasterConnect(): Sending MasterCommand client=TV&connectionmode=1&f=RequestRoute2&homeserver=&ic=**Please do not post TeamViewer IDs**&id=**Please do not post TeamViewer IDs**&id1=**Please do not post TeamViewer IDs**&id2=xxxxxxxxxx&licensecode=00-00000-000000-000000&licensedremoteaccesstypes=0&mid=v4c4c**Please do not post TeamViewer IDs**108053cac04f594a32484d7eee36397633f076e6460ae906117aeb109ff4f6<~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~0dd0c5b4e712d7cef7750d93b4e6b006&midv=2&v=14.0.13880 P
2019/01/14 09:40:07.534 10608 6856 G1 CProcessCommandHandlerMasterConnect[8]::ReceivedMasterResponse(): Received MasterCommand CONNECT@195.244.97.208_10800_128000_**Please do not post TeamViewer IDs**_xxxxxxxxxx_10000__1_0_16778176_128000_16778176:128000;**Please do not post TeamViewer IDs**:1280000;4:640000_**Please do not post TeamViewer IDs**_**Please do not post TeamViewer IDs**_DE-HAM-PLS-R007.teamviewer.com_ef/bc0g5CIhLmAE=_ef/bc0g5CIhLmAE=
2019/01/14 09:40:07.534 10608 6856 G1! TcpCarrierBase[8]::SendCompleteQueue(): No Connections, Type_Tcp, Dir_Outgoing, Ending 0, SendQueue 1, CurrentSendQueue 0, SendCache 0
2019/01/14 09:40:07.534 10608 6856 G1 Activating Router carrier
2019/01/14 09:40:07.534 10608 6856 G1 CommandHandlerRouting[9]::CreateActiveSession(): outgoing session to xxxxxxxxxx via DE-HAM-PLS-R007.teamviewer.com, protocol Tcp
2019/01/14 09:40:07.534 10608 7780 G1 Carrier[8]::EndCarrierInternal(): ClientID: 0 SupportsEndSession: 0, SupportsCCmd2: 0, SessionType_MasterConnect, SendQueue: 0 (4 Bytes), CurrentSendQueue: 0 (0 Bytes), SendCache: 0 (0 Bytes)
2019/01/14 09:40:08.593 10608 2040 G1 Negotiating session encryption: server hello received
2019/01/14 09:40:08.984 10608 8088 G1 Negotiating session encryption: server handshake received, encryption established with AES key length 256
2019/01/14 09:40:08.984 10608 2040 G1 CLoginClient::NegotiateVersionClient()
2019/01/14 09:40:09.343 10608 8088 G1 LoginOutgoing: starting authentication
2019/01/14 09:40:14.329 10608 2040 G1 Login.AuthenticateClient: not authenticated
2019/01/14 09:40:14.329 10608 2040 G1 LoginOutgoing: authentication rejected
2019/01/14 09:40:14.360 10608 7780 G1 CGatewaySession[9]::EndSession(): Session to xxxxxxxxxx ended. Estimated capacity=396kBit/s, Latency=353ms
2019/01/14 09:40:14.360 10608 7780 G1 UDP: create udp connection was not successful: UdpHolePuncher shutting down: (*)
2019/01/14 09:40:14.360 10608 8088 G1! RemoteSession[9]::AddRequestedCarrier(): request carrier UdpToPartner failed!
