Simple connection vs Session
I wanted to know if there are different rules of privilege between the connections made from a TeamViewer client, than those undertaken starting from the links connected to a TeamViewer Session previously created.
It points out that the applicant has a Corporate license, in both series.
The question is: once you reach the limit of available channels for the license, it is possible that it is not practicable a new connection starting from the client, but can be activated from a previous Session links?
I think it is impossible, since even the session link produces the start of the local client (if not already) before proceeding to the connection.
I need your confirmation...
Domenico Langone
Hi DomLan,
your are totally right with your thoughts:
The channel is used as long as the connection is open - if you close a connection, the channel is free again and if you want to open a session code again, you will need a "new" channel for doing that.
Julia
Find this helpful? Say thanks by clicking on the Thumbs Up button.6
Hi DomLan,
Julia
