I am worried that if I use the BLIZZ screenshare, the viewer will see the screen "too small".
How can I prevent that?
If I use a 27'' monitor and decrease the resolution, will the screen be readable (and not too small)?
Thx
It depends also on monitor size of a meeting participant.
But generally reducing the resolution on the presenter side should help if the text is not readable on participant side.
If I use an ultrawide monitor; but then I decrease the resolution,
does the viewer see the screen in a readable size?
See what's new at TeamViewer
