So far as I know, there are two basic methods of connecting to another computer in TV. One involves the special Teamviewer id and password. Since I am not at both computers (!!) I'm not going to be able to get much use out of that.
The other way is by entering the password to that computer. When I am at the correct TV interface for doing that, when I select connect using password I am immediately looking at that computer's home screen and only have to enter that computer's password as if I were at that computer. That I can do.
The problem, and my question, is how to get to that interface. From memory, if I click on the down arrow at "Connect" (extreme top right) I sometimes get a choice of which computer to connect to, and to connect using password, and that means the computer's password, not the TV id or password. Anyway, somewhere there on the right side of the screen, the screen I get when I open TV, there will be one of my other computers and that option to connect using password, And sometimes, like now, those options just will not show up and I cannot find them.
How do I get to the interface I need, the one with those options? Choose computer, connect using password. Right now my options are remote control and file transfer, and control requires TV i.d.. The computer I need is not even showing up now. And it was just there moments ago.
Yes, Just a few minutes ago I had the options I need but I got the message that I could not connect because the other computer was using a different, outdated, version of TV. I got my wife to update it, it's updated now (no, she couldn't find the id, etc., don't ask) but now that interface is gone. My only connection option requires TV-specific codes. How do I get the interface offering "my" way, the easy way, remote control using password, back?
