Is there a way to determine which connection method a session is using (5938, 443, 80) from within either side of the team viewer app?
I'm attempting to confirm if the connections are rolling over to the 443 connection.
Thank you.
Hello Jean;I did a port mapping on my gateway router as per your suggestion by setting TCP and UDP to Port 5938 on my Windows 8.1 laptop with IP address of 192.168.x.x on my home network. TeamViewer was running on this laptop. Next I srtated TeamViewer on another laptop on my home Network and opened a connection to my gateway router (external IP). But the connection did not open. What do you suggest?Thank you.
Sach
Hello @prwashbu,
Thank you for your message. ?
Unfortunately, it is not possible to see this in detail within the TeamViewer client.
You will find all the information you need about ports in our Knowledge Base article here: Which ports are used by TeamViewer?
Best regards
