I have a TV wall that I control through TeamViewer. I have about six computers that login to the wall to change channels/settings. The wall always needs to be logged in.
When I log out the wall computer from my remote computer (LAN connections only) it locks the wall computer. I have "Lock remote computer" set to "never" in the advanced section and it still locks the wall computer. I have also downgraded to TeamViewer 11 from TeamViewer 12 with no success...same problem.
Is there a registry setting that may have gotten "stuck" or a config file that I need to delete after uninstallation? I have also tried to uninstall un-checking "keep settings" and re-install...issue persists.
Edit: BTW...Network is a "closed network".
Edit2: I have noticed that multiple instances are open on the wall computer. When I close out of most of them the "never" lock function starts to work. Eventually more instances open and it starts to auto lock again.
Thanks!
