Hello, is it possible to run apps with hardware acceleration via Teamviewer?
I mean these apps are starting but I can't see it properly on the screen, but when I disable hardware acceleration in properties of it, everything starting to work fine.
The problem is that not all apps allow you to disable HA manually.
