Teamviewer meeting
ALT130
After updating to version 12, it is not possible to join a meeting with a host running on version 11. Any chance on bypassing that or an expected solution?
Hi ,
Thank you for your post
It because of version difference. higher version cannot access lower version.
Please use Quick join V11 that is only way you can join a meeting.
Thank you !
That seems strange to me as with a normal remote control session there is not a single problem to connect to an older version of Teamviewer. I would have expected the sama would apply for meeting sessions.
