Add support for Ubuntu Server 20.04 LTS 64-bit on Raspberry Pi (aarch)
computeronix
computeronix Posts: 3
edited April 27 in IoT Forum
Ubuntu Server 20.04 LTS supports 64-bit on Raspberry Pi.  However, the architecture is aarch and when attempting to install TeamViewer it will not run as this is not supported.
Please add support for this: https://ubuntu.com/download/raspberry-pi
The GUI environment used for this test was Ubuntu Desktop.
«1
  • mircea_c
    Hello @computeronix
    I sent you  some day ago a pm.
    You manage to test it?
    Tech Support IoT
  • bergi
    bergi Posts: 3
    Hi
    I would like to test it as well. Can you send me the link to the 64 bit test version?
    My system:
    Linux raspberrypi 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
    Kind regards
    Peter
  • mircea_c
    Hello @bergi
    Please check your messages.
    Mircea
    Tech Support IoT
  • lmcal6
    lmcal6 Posts: 3
    Hello, I would also like to test this as I'm in the exact same situation. Could you also share it with me?
  • bergi
    bergi Posts: 3
    Hi
    I use this os version on a raspberry pi 8GB but there is no *.deb version for this available.
    uname -a
    Linux raspberrypi8gb 5.4.42-v8+ #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020 aarch64 GNU/Linux
    Peter
  • mircea_c
    edited March 30
    Hi @lmcal6
    The aarch64 package is for the TeamViewer IoT Agent and is different in features from normal (host) TeamViewer App. If you want, I can send it for testing. More information about TeamViewer IoT here
    Mircea
    Tech Support IoT
  • lmcal6
    lmcal6 Posts: 3
    YEs I would like to have it for testing, thank you.
  • mircea_c
    Hi @lmcal6
    Please check you pm.
    Tech Support IoT
  • Chricchio
    Chricchio Posts: 2 ✭✭
    Hi
    Thx!!
  • bergi
    bergi Posts: 3
    As I know there is no Teamviewer version available which allows to share your Desktop.
    Peter
  • Chricchio
    in the previous post,someone talk about a "test version" sent in pm
  • Hi @mircea_c
    Can you also send me the link of the test version?
    I'm running 64bit ubuntu server on rpi 3 b+
    Thanks in advance
  • mircea_c
    Hello @sam749
    Please check your pm.
    Mircea
    Tech Support IoT
  • I'd also like to test the version for the Pi4 running 64-bit Ubuntu Server 20.04 LTS
    John
  • mircea_c
    edited March 30
    Hi @seanty
    Mircea
    Tech Support IoT
  • Hello mircea_c
    Please send me the test version as well. I am running a RPi4 64bit and I would like to give it a try since nothing else works.
    Thank you!
  • mircea_c
    Hello @xynroot
    Check your PM.
    Mircea
    Tech Support IoT
  • Does this version work on Ubuntu 20.10?
  • mircea_c
    edited March 30
    Hi @Alastar
    The IoT Agent should run on Ubuntu 20.10 on aarch64.
    Please take in consideration that the Agent has different features and use than TeamViewer Host Module.
    Mircea
    Tech Support IoT
  • Hello @mircea_c ,
    Can I also have the aarch64 version, please?
    Thank you!
  • Also having this issue. Can you send the testing version?
    David
  • mircea_c
    Hi @dha-hc
    The testing version for aarch64 it is for the Teamviewer IoT Agent which have different feature that Teamviewer Host.
    Mircea
    Tech Support IoT
  • votecoffee
    votecoffee Posts: 1 Newbie
    Can I get a download link as well? Running Ubuntu Desktop 20.10 x64 on an RPi 4
  • Eleftherios
    Eleftherios Posts: 1 Newbie
    Hi @mircea_c,
    Is there a beta version of the TeamViewer Host for arm64 (Raspberry Pi4 running Ubuntu 20.10) I could possibly try?
    Kind regards,
    Eleftherios
  • mircea_c
    Hi @Eleftherios
    Unfortunately, this is not ready yet.
    We will announce on the community when it will be available.
    Mircea
    Tech Support IoT
  • adivinaquien1
    adivinaquien1 Posts: 0
  • mircea_c
    edited March 30
    Hi @adivinaquien1
    Mircea
    Tech Support IoT
  • Jorn123
    Jorn123 Posts: 0
    Hi @mircea_c
    Still no final version of the IoT Agent for Ubuntu 20.10?
    Is it possible to get access to the beta?
  • mircea_c
    edited April 2021
    Hi @Jorn123
    The IoT Agent should also work for Ubuntu20.10 on this architecture ARMv5hf, ARMv7hf, X86, X86-64
    You can login on the teamviewer-iot.com and click on "Add device" select "Debian" and select "Custom Installation"
    Please keep is mind that this is not the Teamviewer Host (used for remote control)
    Mircea
    Tech Support IoT
  • fbs_mike
    fbs_mike Posts: 1
    Hey @mircea_c,
    Could I get a copy of the aarch64/arm64 version of the IOT agent as well. I have a PI 4 running Ubuntu Server 20.04 LTS 64bit which is an IOT device.
