[TV 12] Running Teamviewer in just one window?
JohnPvblic
I used to be able to fire up Teamviewer, connect to a remote host, then close the main Teamviewer window while keeping the connection window open. I don't know if it's the newer version, or a changed setting from fresh install (installed Windows 10 recently), but now closing the main window closes the connection window, too.
Is there some setting I can change so I can close the main window without closing my connection?
This may be a little late but in settings under "Advanced", the first section is "General advanced settings" and there is an option to Close to tray menu. Check that box and closing the main TeamViewer screen will no longer close the connection window(s).
