can't connect from android and iPhone to Team Viewer on windows 10 - all TeamViewer in version 12
why can't i connect from android or iPhone to windows
if i install on windows Team Viewer Version 9 then i can connect - with version 12 not - why?
is there any solution?
windows Team Viewer version: 12.0.7816
android Team Viewer version: 12.2.6961 CL
iPhone Team Viewer version: 12.1.79134 CL
license: both freeware
error message: your current license is not compatible with your partners TeamViewer version. you nedd to update your license to the current version
Dear @waldemar
Thank you for your post. The connection depends on the version of license you purchased.
It sounds like you are using a version 9 license. Could you please check this first?!
And if so, you are able to support clients where TeamViewer version 9 is installed or started.
If you need any further information for your license issue or updates please contact our salesteam, they will be happy to help you. :smileyhappy:
Reyhan0 -
Thank you for your answer, but i described the versions i use in my post:
Windows 10 Team Viewer version: 12.0.7816
Android Team Viewer version: 12.2.6961 CL
license: both freewareThis Versions do not working together.
Hi @waldemar
Thank you for your fast reply. Do you sign in with your TeamViewer account?
If your account is licensed with version 9, you may not support version 12.
Reyhan0 -
Hi again :-),
i really don't know how is my accout licensed. In fact i started years ago with the Version 9. But now i use version 12 and i can use my account with version 12 when i connect from one windows laptop to other windows laptop. the connet is only refused when i try to connect from android or iphone...
Was there ever an answer for this? Their support site is **bleep** at best.
