Easy access
is there a way of establishing connection between 2 pc's without having to enter a new passord each time?
    Hello @hedart
    Yes, it is possible.
    You can enable Easy Access on your remote device: How to enable Easy Access
    After setting this up, you will be able to connect to it with a simple double-click.
    I hope this could help. ?
    Best regards
