start teamviewer 12 on reboot
salscarpato
does teamviwer 12 automatically load on reboot? If not, how can I make it start on reboot?
It can if configured (and asks if you want it to durring initial install). If it is not, or you would like to check the setting go to options and look at the check mark that says "Start TeamViewer with WIndows" (Yellow Aarow)
Bart Lanzillotti0 -
I am doing my day to day work on a computer using a non administrator account (I understood that this is best practice). Can Team viewer autostart in this configuration?
Attached is a screenshot from Extras -> Options.
