Problems with TVOPT and software deployment
Hello all,
we are installing Teamviewer with our Softwaredeploymenttool Baramundi. Everythings works well, only one small topic I have a probkem with. We bring standard settings with the *.tvopt File to the client while the installation. The problem is, the installation runs under an admin user and we haev a setting which should goes to the logged in user:
[HKEY_CURRENT_USER\SOFTWARE\TeamViewer\MultiMedia]
"RemoteAudioReceiveEnabled"=dword:00000000
It looks like, that this is not imported correctly, because the Audi is always on. Does anybody has an idea how I can deactivate for all users the remote Audio while the installation?
  • RyLM
    RyLM Posts: 4 ✭✭
    Have you try in HKLM? [HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\TeamViewer]
  • Linki3030
    Linki3030 Posts: 2 ✭✭
    Yes, and also HKEY_USERS\.DEFAULT\Software\TeamViewer\MultiMedia
    No change :-(
