Teamviewer Meeting opens Outlook Mail/Invitation in TXT
RWB_St
RWB_St Posts: 11 ✭✭
edited April 2023 in Meeting Forum
Dear all,
I've the problem, that Teamviewer Meeting is opening the Email / invitation in TXT format, leading to the problem, that the Meeting link is not working at the recipient. (Plain text instead of hyperlink)
Who can help? Thanks
  • Esther
    Hmm - that´s interesting, especially as the other two links are displayed correctly.
    I tested it myself and when opening up the invitation in outlook all links are shown correctly.
    Does this happen only for this meeting or for others too?
  • RWB_St
    RWB_St Posts: 11 ✭✭
    That happens at all invitations... :-(
  • Esther
    What version of TeamViewer Meeting do you have at the moment?
    You can check it here: Settings --> About TeamViewer Meeting
  • RWB_St
    RWB_St Posts: 11 ✭✭
    edited January 2021
    Here you are, and thanks for caring :-)
    (Should be the latest version)
  • Esther
    Yes - I have the same version. I need to check with the meeting team - I will get back to you!
  • Esther
    edited January 2021
    Ok - back already: Can you check in your Outlook under File --> Options --> Mail what is being set under Compose messages in this format?
    Mine is set to HTML and I get the proper links from TeamViewer Meeting:
  • VoHammel
    VoHammel Posts: 4 ✭✭
    I have the same problem, that @RWB_St described.
    Checkedmy MS-Outlook settings. It's like in the post of @Esther .
    Everything was fine in the past, since we updated to 15.13.6 this is the second problem with meeting.
    The "funny" thing - if I start a meeting, add members with this button
    and open the mail to invite outlook opens the mail in html and a proper link is displayed
  • Esther
    Hi @VoHammel Thanks for joining us!
    Just to confirm:
    • When opening the invitation from the Scheduler, the invitation link is displayed in HTML instead of a hyperlink,
    • your Outlook setting is "HTML" and
    • when inviting someone from within the meeting via email, the link is displayed correctly.
    Did I understand you correctly?
    I think it would be good to have some others testing it too. I encourage everyone to test this, also when using other email programs. As I know that @JeanK , @Natascha @Yuri_T are using Outlook, can you check this scenario too?
  • Natascha
    Hi there,
    Thank you @Esther for the shout-out 😉
    Just tested it and I'm sorry to tell, but changing the options in Outlook under File --> Options --> Mail what is being set under Compose messages in this format didn't make any change to the formatting of the meeting invitation.
    Maybe the others could report something else?!
    Hope we can solve this anyhow 🙏🏼
    Wish you all a great day.
    Natascha 🙋‍♀️
    Hi everybody,
    I couldn't reproduce the issue. The link are displayed correctly no matter which Formatting setting I choose in the Outlook options.
  • Esther
    Hi again! Thanks for your help Natascha and Jean 🙌
    I now also changed the settings in Outlook to RICH and checked again and I can confirm, that this also results in a correct link in the email. I will get back to the Meeting team asking for an idea.
    edited January 2021
    I might have found a setting that leads to insert plain text instead of hyperlinks.
    Maybe you could give it a try and make sure this setting is not set up within your Outlook options:
    1) Click Home > New Email to create a new email.
    2) In the opening Message window, please click File Options.
    3) In the Outlook Options dialog box, please click Mail in the left bar, and then click the Editor Options button in the Compose messages section. See screenshot:
    4) Now you get into the Editor Options dialog box. Please click Advanced in the left bar, and make sure the Show field codes instead of their values option in the Display e-mail content section is unchecked; and then (3) select Never from the Field shading drop down list.
  • RWB_St
    RWB_St Posts: 11 ✭✭
    Hi everybody and thanks for your support!!!!
    Jean: I seem to have a different Outlook Version, therefore the menue looks different:
    Flied Shading is not exitstent :-)
    So, what's next....?
    Hello @RWB_St,
    You need firstly to open a new E-mail and from there you need to access the options. Then will get the same as I see.
    If you go straight to the options, without opening a new e-mail, you won't see it.
  • BTB_HSM
    BTB_HSM Posts: 3 ✭✭
    Having the same issue. All the settings are correct as stated above. However, when creating the new invite, the text format is being selected as Plain Text. Does anyone know a way to change the default setting to HTML? Even if I manually change it to HTML, the prefilled information stays the same.
  • RWB_St
    RWB_St Posts: 11 ✭✭
    Hi BTB,
    by deleteing "<a href=" and "0>Join>/a.." and pressing enter at the end of the line, the text change to LINK, if you have selected HTML.
    That's my current "work-around".
    Not comfortabel, but working.
    Regards, Stefan
  • BTB_HSM
    BTB_HSM Posts: 3 ✭✭
    RWB,
    Yes, that is what we have been doing as well.
    The only problem with that is having to tell all of the "non-technical" people how to do that correctly every time they use it.
    Thanks.
  • VoHammel
    I have exactly the same situation than@BTB_HSM posted
    It seems that the parameter "@@URL:MID@@" which teamviewer uses to generate the mail/the invite is broken.
    Every other parameter works propper.
    @RWB_St how many letters must be deleted to get the right link? I checked meeting invittations from last year. The link in these old mails ended with the meeting-ID. For the example above means this you have to delete the "<a href=", the "?" and all letters right of the "?". This is also the structure in the test text that can be displayed in TeamViewer Options.
    Since TeamViewer 15.13.6 the only thing that works as expected is "TeamViewer Remote Access & Support".
  • BTB_HSM
    BTB_HSM Posts: 3 ✭✭
    IF you edit the string as follows, it works correctly...
    Remove everything highlighted:
    Hello @BTB_HSM, @VoHammel and @RWB_St,
    Our development team is aware of the issue and is currently working on a fix.
    The fix should be deployed in the next update, so need sure to keep your software up-to-date 😊
