Teamviewer is running an old version which is out of date / no connection anymore !!
It started about an hour ago. It was working fine up to that point.
I even tried a clean install on both machines. No luck. And the software version is definitely the most up to dated on both PCs LOL
It seems to be a problem on the account or registered computers.
Same connection problems (Free Versions), altough updated software 15.15.5 on both sides...
Yep same here, have it installed on 3 PCs, all up to date and getting the same message.
I am having the same problem. Have updated both mine and my elderly father's version of TeamViewer but its still telling me that it is out of date. He relies on me being able to help him with his computer and not being able to connect is really difficult.
Will TeamViewer be fixing this problem soon?
Chat between the two hosts works so there is some form of connectivity but Remote Control is broken.......
Same problem here. Both hosts have the same version but it says the remote host is out of date
I am having the same problem as well
The same problem!!!!!!!!!!
Possibly fixed? I've just tried again and been able to connect to my server (although TV was a bit slow in starting and connecting)
Still the same problems here.
Issue is fixed on my side! able to connect with no issues!
thx for the swift reaction @TeamView_free !
Fixed here too! Thanks!
