Are you working with Insider Builds❓
Participate in our survey and get to know the new UI 👉 here 👈.
How To Secure or Disable ctr alt del on Remote Black Screen
I am working with remote computer that has black screen activated, and I was wondering if there is a way to prevent the remote computer's black screen from being removed (by ctrl alt del)? I would like for there to at least be some password challenge if a user at the remote computer presses ctrl alt del, before revealing the computer screen.
Thanks for any help,
Louis
    JeanK Posts: 4,882 Senior Moderator
    Hello @Louis23,
    Currently, there is no way to prevent the remote computer's black screen from being removed by ctrl alt del.
    However, the computer will be locked (and therefore, the user password will be needed to log in again) and you will be immediately informed once the combination is pressed.
    Tell us your Computer Nightmare Story and let's scare each other - Happy Halloween! 👻🎃
    French Community moderator
