CONNECTION PROBLEM
naveed
Posts: 2 ✭✭
GOOD DAY EVERY ONE I HAVE PROBLEM ON THE CONNECTION AFTER LOG IN THE CONNECTION LOST VERY QUICK ITS RECONNECT AND LOST AGAIN JUST CONTINUES LIKE THAT
ANY ONE CAN HELP IN THIS REGARD
if you mean you are connecting to a pc and getting the connection timeout after a 1-2 minutes, I'm having the same problem. It is making the software unusable because what can you do in under 2 minutes and then you cannot reconnect for a period of time.
Actually is not time period it’s just lost connection and reconnect again it’s self
according to what I understand it’s internet problem r Pc problem
so I’m looking the solution of it
