1247248250252253350
  • Valle50
    Valle50 Posts: 0
    edited March 2021
    Dear Teamviewer
    I am a member of yours as Renato ** Removed due to Privacy ** (ID teamviewer:** Please do not post your TeamViewer ID **) and again when I log in it tells me that my session has expired and does not allow me to connect with my friend in private mode and not for COMMERCIAL USE. in the past I have already had this problem and you have kindly solved it. I ask you to verify precisely that my connection is not CONTINUOUS OR DAILY OVER TIME and is indeed private and not COMMERCIAL. Thanks in advance for your intervention to resolve the problem and best regards
    Renato ** Removed due to privacy **
  • jiminboston
    jiminboston Posts: 0 Newbie
    Same issues. And as well received an email from TV asking me to fill out a reset form. I filled it out, but it wouldn't generate the pdf file. What gives???
  • twnorth
    twnorth Posts: 1 Newbie
    Please please please help i mostly use the TeamViewer to set up services for sunday and the weekend is Easter and i have 4 services to do.
  • Jim_S
    Jim_S Posts: 2
    I did the account reset although maybe I didn't need to. Accounts were reset none the less 5 days ago and
    I still keep getting the timeout message after a minute. Should I uninstall and reinstall?
  • bflotim
    bflotim Posts: 1 Newbie
    I am being timed out in 30 seconds and am unable to re-connect.
  • jdiaz61304
    jdiaz61304 Posts: 1
    This is happening to me as well. I was fine and able to login for long periods then all of a sudden between 30 seconds and a minute or so it cuts off. I am not using it for business and only logging into my personal device.
  • Rideout18
    Rideout18 Posts: 1 Newbie
    edited March 2021
    I'm having the same issue. Times out at 30 seconds then pops up the following error.
    I have to wait a good bit before I can reconnect. Then once I reconnect, I get disconnected after 30 sec.
  • lala29
    lala29 Posts: 1 Newbie
    I use Teamviewer for personal use, but recently I've been having an issue where I get timed out of my connection after just a few seconds. It then refuses to let me reconnect for several minutes. I tried to reset my Teamviewer IDs at https://www.teamviewer.com/en/reset-management/ 3 times, but it didn't solve the problem. I also uninstalled and re-installed the app. Any advice would be much appreciated!
  • themediacloud
    themediacloud Posts: 1 Newbie
    edited March 2021
    Regarding account : ** Removed due to Privacy **
    Connection between my MacBookPro and my MacMini
    Hello support
    Im using teamviewer ONLY for private matter, i dont work, and dont have a company, so why are your service giving me a timeout after 10 seconds ??
    I have downloaded and chosen private in the installation, help me remove the timeout, i cant use it at all, and i dont understand why this is happening ?
    https://www.teamviewer.com/da/teamviewer-automatisk-download/
  • towt
    towt Posts: 4 ✭✭
    Having the same issue here.
  • HACHIBI
    HACHIBI Posts: 1 Newbie
    When I try to control my home computer from my mobile phone, I get a commercial use detected error.
  • harald_schweitzer
    harald_schweitzer Posts: 0 Newbie
    edited March 2021
    I was using Teamviewer for years only for private reasons (to help my kids doing their work on Laptops or assist my parents with troubles on their computer).
    So I think this use is ok for a free license? But in the last weeks, I cannot use it anymore, because connections keep being disconnected and followed by a lock-out from being reconnected.
    The error message is: (free translated from german)
    "This was a free session sponsored from teamviewer.com" and
    "This session has timed-out and will be closed now" and
    "Connection is locked after timeout. Your license limits the maximum session duration to a partner, new connections are getting blocked. Please try it later again. Connections are blocked until xx.yy"
    Does anybody has a clue, what I'm doing wrong?
    Thank you,
    edit I'm using Win10 x64 with up2date Teamviewer 15.16.8
  • Tsherod3
    Tsherod3 Posts: 1 Newbie
    I am getting an error every time I try and remote in to my home computer that is telling me I am blocked and to wait. When I wait and go back in, I am in for 30 seconds and kicked back out. Why is this happening on a free account?
    Why is this happening on my free account? Please help.
  • JimmyJoe
    JimmyJoe Posts: 1
    When I connect to the other computer with my computer, I'm booted out very quickly. Then, when I try to log back in, I get an error that I can't reconnect after a certain period of time.
    How do I fix that?
  • OCallaghan
    OCallaghan Posts: 1
    I have been having this same issue for 2 days now
  • why am i being timed out ?? need help
  • After Logging in to my remote PC I am terminated after just a couple of minutes. Why am I being
    logged off after such a short interval??
  • MShoeb_Hasham
    MShoeb_Hasham Posts: 2 ✭✭
    good morning, i have an account on teamviewer, it happens that when trying to access other computers, namely 3 raspberry pi, he does not let me. or rather the connection blocks. I think it’s because he says I’m using teamviewer for professional use. But it's not the case. I only call Pi once a month to update a few times. I use the teamviewer for personal use only. how can I resolve the situation. I needed to access the pi to update the April times. the pi are connected to televisions that show schedules.best rgds,
  • Robibadabi
    Robibadabi Posts: 1 Newbie
    I've been using Teamviewer for many many years for personal use only and today started getting """""Connection blocked after timeout. Your license limits the maximum session duration to a partner, immediate reconnects are blocked. Please try later or upgrade your license. Connections to this partner will be blocked until 13:28""""" When I try again after said time it comes up again but it's 1 minute more for the time. I went to check prices and GULPPPP!!! I can't believe the prices. I only use it to log into my PC's and raspberry's in the house to monitor my 3D Printers and IoT devices that are outside or in the basement. I would definitely purchase a license if they had a personal use "Price Point".
  • OLIWIA
    OLIWIA Posts: 1
    Hello, I am private user, I've registred my email, but I can not use TeamViewer for free anymore.
    Can You please maybe help me with this problem?
    I've tried to reinstall teamvier for first,
    I've tried to buy license, but I am not company and your system didn't let me in too :)
    Thank You for your help
  • murfjs
    murfjs Posts: 0 Newbie
    Robibadabi. Please forgive me for being one of the "yes, me too" peoples. But am having the exact same issues as well. And rather than create another post stating the same, hopefully I can monitor this post and, if we are lucky, sooner than later we might both get a resolve. My only difference is I use mine to help family members (I am somehow the volunteer IT guy) and occasionally move files from one personal pc to another personal pc when storage becomes an issue. Thank You, murfjs
  • Marylynne
    Marylynne Posts: 2 Newbie
    after I log into my partner computer I keep getting kicked out after less than a minute.
  • mcburwell
    mcburwell Posts: 1 Newbie
    In the new implementation (since 27Mar21), is it possible to validate that I am using TV for non-commercial, private use and therefore be allowed to use it without payment in an unfettered way?
    TV's has just-implemented V15 (and auto-upgraded me) as well as new automated actions against unpaid commercial use. I have been an unpaid user for four years, employing TV to check cameras at our weekend home from time-to-time. This is very cleanly "non-commercial, private use."
    However, since 27Mar21, upon remotely connecting, I receive a message saying TV believes I am using their software for commercial purposes and I will only be allowed 5 minutes' use. TV then automatically breaks my remote connection 30-60 seconds after it is established, accusing me of employing the system for commercial use.
  • Marylynne
    I don't understand why I'm getting kicked out of my free non-commercial use TeamViewer after less than a minute.
  • MrSzymon
    MrSzymon Posts: 1
    I've been using TeamViewer free for many years for my personal usage to control mini pc's on my telescopes. For the past few weeks it seems my 'timeout' has been set to 30 seconds without retries. Literally I can connect for 30 seconds and then it disconnects, and trying to connect again gives me this message:
    I have a confirmed non-commercial license, which has been explicitly set by TeamViewer Support as not commercial.
    What can I do to make it work?
  • life777eternal
    life777eternal Posts: 1 Newbie
    Hello, last year I had a message appear saying that "This software seems to be used in commercial environments. ..." when it's really not a commercial environment. Now all the TeamViewer connections are being disconnected after five(5) minutes or less.
    Then after that appeared, there was a "Session Timeout" message:
    And then an "Unable to connect" message:
    Is there any way that this can be fixed so that I can help friends on their computer again from home?
    Thank you.
    The blokes at the TeamViewer phone support won't talk to anyone without a paid license. Which is $730.80 per year, at the minimum.
  • life777eternal
    Thank you.
  • MrSzymon
    MrSzymon Posts: 1
    My message was moved to this post, but I think it was moved incorrectly. I am not getting “commercial use detected” messages. Like I wrote, I am a confirmed non commercial user. I used to get commercial use detected messages, but I registered (sent a signed sheet etc) and the message I receive (as per screenshot) is nothing to do with “commercial use detected”.
    any help available?
  • KenHill
    KenHill Posts: 2
    My session starts and runs OK for about 5 minutes then I get a popup; The title of the popup is "Sponsored Session" and says "This was a free session sponsored by www.teamvierer.com" and it quits
  • BillS92787
    BillS92787 Posts: 0
    I get the same lovely message filled out the form and everything and still the same song and dance. Teamviewer use to be good but this **bleep**! I rarely use this connection and it's for connecting from my phone to pc and maybe 3 other personal computers. ZERO COMMERCIAL USE but no way to fix it even after signing the form and sending it in I've heard NOTHING from TeamViewer on this. Time to look elsewhere save yourself the headache and just google another program.
