Teamviewer 15.16.8 does not show gui
MaitreDede
MaitreDede Posts: 4 ✭✭
After an update of teamviewer to version 15.16.8 amd64 on debian buster (latest updates + backports), the teamviewer UI does not show, and when launching client with console, it does not show any error. Only :
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
  • astricker
    astricker Posts: 0
    I'm using a dedicated Debian Buster 10.9 VM with a clean XFCE Tasksel installation and VirtualBox tools for my TeamViewer environment. Of course all current updates are installed. It stopped working after recent Update on 2021-04-07 to TeamViewer 15.16.8 amd64 using dpkg/apt. It will connect to the remote host and display a recent screen of the remote host, but then freezes: No display updates and no keyboard or mouse inputs nor chat messages will be transmitted.
    It seems like the /opt/teamviewer/tv_bin/TeamViewer process is hanging in a FUTEX, as it will only go away when killing with SIGTERM before restarting. Otherwise no reconnection is possible at all.
    I've already tried to reinstall the TeamViewer with no success (apt remove --purge teamviewer && rm /home/astricker/{.cache/TeamViewer,.config/teamviewer,.local/share/teamviewer15}).
    In the TeamViewer Logfile are not obvious errors at the time of the hangup. But I'm not an expert here.
