Default vertical screen orientation.
Hi, I wanted to ask, when I take screen control with teamviewer, on Ipads when I use certain applications and the default orientation is vertical. How can I orient horizontally? Thank you.
    Hello @Giorgio85,
    It is not possible to enable horizontal mode as default for some applications, as it depends also on the applications themselves.
  • Giorgio85
    Giorgio85 Posts: 2 ✭✭
    Hi thanks for the reply. Can I change the orientation from time to time? Thank you.
    If you change the orientation on your iPad as described in Apple's article below, the TeamViewer connection should follow the change:
