Can I try an older compatible version?
Thanks very much for that information.
Hello @stefblan,
You will find here the versions/OS compatibility tables:
📢 If your OS does not support the latest version of TeamViewer, (currently 15.16.8), a license will be required to connect/use your computer with TeamViewer.
