Commercial use - Connection time outAnnounced
๐ Request your reset here ๐
Read my Blog article to find more information about Commercial usage and the link to request the reset of your TeamViewer usage:
๐Click here for reading the blog article๐
Further articles:
Why do I see 'Commercial use suspected' / 'Commercial use detected'
๐ Please be aware that this is NOT an issue that can be resolved in the community. Posting messages about commercial usage will not help to get the reset. For getting a reset you need to fill out the form.
๐ Please be informed that the Community team is merging all posts about this topic underneath this post. We are doing this to make sure that users finding the right information quickly when using the search function.
If you are using TeamViewer for your employment or in a business setting, please contact our sales department to find out how your company can benefit from using TeamViewer!
See also: https://www.teamviewer.com/en/pricing/commercial-use/
Thanks and best,
/JeanK
Find more posts tagged with
Hello there. Some weeks ago I send a request via the form to teamviewer company because I had the usual problem of suspected commercial use. Thankfully, the company replied and declared my PC account, free non commercial.
At that point I was happy but after a few hours I discovered that my other computer, a MacBook (which of course is registered under the same account/password I use for teamviewer), had a different ID and it started to suspect commercial use and dropped the connection.
I don't understand. Isn't teamviewer system able to see that both computers are under the same free account holder?
Do I have to send a new free use teamviewer form the company?
Hi
I accidentally logged into my private teamviewer account on a corporate machine and now I can't have sustained sessions for private use because corporate use has been detected. I have logged into the corporate account now, so I can use the corporate account without issues, but my private account is now treated as corporate user without license.
How do I "reset" my private account to its free status? I have already deleted the corporate machine from My Computers on my private account.
Thanks!
Hello!
I have several PCs at my friends home and at my home
Computers work autonomously, for example, mining or parsing.
Sometimes I need to remotely check and fix the process on PC
Often there is a problem with the license.
I do not have a company, this is a home project.
Can I solve the problem with the license and use the free version?
I am trying to use Free Teamviewer to assist friends and family with setting up addons for World of Warcraft and every time that I connect to one of them to try and do so I get disconnected with a timeout message after 30 seconds. This issue makes it impossible to help anyone since I cannot stay connected long enough to help them. How can I fix this issue?
Thanks in advance.
Michael M
Same problem. Once I've connected to my personal computer from work network and now I'm disconnected from any network after 15 seconds of usage (probably a bug) with 15 minutes of timeout.
Looks like my account was generally marked as commercial. Cannot find any options to resolve this misunderstanding.
I know that Free accounts is not a priority users for Team Viewer, but such behavior literally pushes to migrate to other solutions. Is that the purpose you trying to aim?
This happens usually when I run Teamviewer from my computer at work to connect to my computer at home. It's personal use, nothing to do with my work, but since it's an enterprize environment and network, I can understand the confusion.
What bothers me is that it's now spread to use from my mobile phone as well and even when I use a private computer in my own house to connect to another private computer in my own home.
Have had this issue for months now and not gotten any response from TeamViewer, despite having had a registered license for 5+ years now. I am not willing to pay [The price has been removed in accordance with the community guidelines.] for this service so if I can't find a solution to this I'll have to switch to another, inferior, product.
When activating my machine on my user I was classified as a business user, but I use TeamViewer only to access my other machine when I'm traveling - and I don't use it for commercial purposes or user support - how do I solve this problem?
I've tried reinstalling the software but it didn't work and I looked on the site here in Brazil and I'm only aware that ChatBot doesn't solve my problem ...
Hey @Sapass -
Nope, it says "Free License (Non-Commercial Use)" at the top of my TV window, so it is not that. Something else is happening here causing sessions to just close after 1 minute.
@Michaelweb93 wrote:Hello,
I have a MAC and I have updated my TeamViewer to the latest version.
But now for free as a private individual nothing works and only for "commercial use".
How do I get private use?Thanks is urgent and regards.
Michael
Well it took quite some time go get back to being non-commercial. One must fill out a declaration (and sign it) that confirms you are not a commercial user. All this is a pain in the nether sides and whether all this helps is also questionable. I am now trying out **Third Party Product** -- so far that is free. I understand that Teamviewer must make money and I would buy a one-off price for TeamViewer for non-commercial usage....if not too expensive.. But the current commercial or not detection does not work well - if at all.Teamviewer need to address this, assuming it is now a company policy to make life difficult for non-payers.
Hi Jason,
Make sure you are not, like i am, false detected as a commercial user of TV. Teamviewer has now an agressive politic with personnal user to force them buying a pro licence. It shut down connection afeter one or two minutes, and it block reconnection for 10 minutes.
There is a page on their site to alert false positive but, in fact, they never respond (i tried 3 times) and all we can do is stop using this software and find an alternative. I actually use RDP for my HTPC, but i still didn't find a way to help my blind father with his phone.
Thanks Teamviewer (
ok so i have used teamviewer if i can remmber in 2012 or so i have always used it free because i only conect to my main computer and my home server in the other room. lately i have been having issue with conecting to my server yet i have done then for the passed 3 years when i had issues. i have no idea why teamviewer thinks im useing it commercially yet im only going on my server/home pc so if this cant be fixed or i cant get help i will have to find another way to remote into my two computers
~Cody .S
Hello -
I recently upgraded my Late 2012 Mac Mini to Catalina and Team Viewer no longers works, whereas it worked perfectly fine before updating the OS and to TV version 15.
Every time I start a Presentation, it starts up normally and then within a minute it shuts down on its own saying the "Session has timed out".
I've checked all permissions in my Mac's settings and everything was granted full access, so I am not sure what is happening here.
Any insight would be much appreciated.
@johnzageek wrote:
If you are just helping a friend with something on their system, that is not a violation of Teamviewer TOS.
I was not even outside my local WLAN. That is what surprised me when I got falsely
Charged with being commercial. I still think VPN had something to do with it.
Then why and how does teamviewer "know" whether I am using a free version commercially or not?
What must I do to stop this happening again -- the reassignment to non-commercial took a long time.
I have been falsely classified as commercial although I am using Teamviewer for my own home computers. It took a long time to get reaccepted as a private user and I switch to **Third Party Product** - which I find just as good as TeamViewer. I cannot trust Teamviewer since I think the commercial check is error prone.
I hope this get sorted out.....
@Bonzadog wrote:I now regularly use a VPN (may change location).
Was this the reason why my non-commercial activity was regarded as commercial and blocked? .
Not likely. Teamviewer in and of itself is a VPN baqsed app. Multiple VPN connections can certainly gum up the works. But teamviewer uses what would seem, a fairly overactive polling system <client <---> server> to validate the apps usage.
I have the same problem, and would like to find out how to explain to TeamViewer why I believe I am definitely a "Personal Use" user.
I have only 2 laptops in my house (registered with TeamViewer) plus now, as well as my elderly (96 year old) mother's old Win 7 desktop PC, a new Windows 10 based laptop, which I am going to transfer her usage across to, as I can teach her to adjust to the differences. In fact, I virtually never use TeamViewer (as wonderful as I know it is) except to keep a check on how my dear old Mum is going. We live in country Australia, some 50 kms apart, and mum lives alone. Any help greatly appreciated. Iankett
Hello!
I've fileed the form complainting of wrong suspection of commercial use more than 2 weeks ago, but still didn't get the answer to my email. Could you help please? The email is the same as in my account
Thanks in advance
