TV Management Console Filter Options
I use this all the time to bill my clients. I go to All Groups then Connection Reports. I want to be able to see only Unbilled in my list so therefore, those with no tick. Am I missing a way to isolate those?
Regards.....Mark
    Answer ✓
    Hello @NichoUnited,
    There is no proper feature to isolate the unbilled connections.
    However, if you click on Billing, all the billed connections will pop at the top of the list.
    If you click a second time on Billing, the billed connections will drop down and the unbilled connections will pop at the top of the list.
    You will then see and isolate the connections that have not been billed.
    I hope this will help you.
    Answer ✓
    Hello @NichoUnited,
  • NichoUnited
    NichoUnited Posts: 4 ✭✭
    Thanks for the response. I would like it as a filter so I could then apply other filters on top but it is what it is.
    Regards...Mark.
