Force logout
Hello, I have a single channel and wanted to know how I can force my login to log me out if I forget to logoff.
I accidentally left my computer logged in, and needed to connect when I got to a different location to realize that I'm still logged in at the 1st location. How do I force the logout on that 1st computer, so I can log in at my 2nd location?
Thank you, Jeff
Sort by:
1 - 3 of
31
Hello @JeffCMG,
Yes, you can enable a timeout that will disconnect you in case you forget to disconnect:
Example: Setting it on 1 hour, it will disconnect the inactive session after 1 hour of inactivity.
Hi @MSulewski,
Yes, this parameter also exists in the TeamViewer policies:
JeanK
