Unattended Access
Before Version 15.18.5 i had setup easy access on some client, and i managed to connect without any user interaction.
After latest build, even if easy access is configured, on client before i can see or interact the screen some one should click on Show desktop (i presume it is the correct translation, as my TV is in italian).
Why i cannot anymore do the unattended login ?
Fabrizio
  • Esther
    edited June 2021
    HI Grisu70,
    Would you do me a favor and check the settings on the remote device under Extras --> Options --> Advanced --> Advanced settings to this computer --> Access control
    What is set there?
    And do you see this when making the connection:
    Thanks, Esther
