Which mobile app do i use on iphone?
Hi there,
it depends on what you want to do:
- If you want to start Remote Control sessions from your iPhone, use the Remote Control app.
- If you want to receive connections for screensharing, use the QuickSupport app
Hope that helps.
Esther
Former Community Manager
Hi there,
Hope that helps.
Esther
