v9: Enable automatic updates via registry?
ndrake
ndrake Posts: 3 ✭✭
I need to update a bunch of TeamViewer hosts running v9 to the latest version. I was hoping to just turn on automatic updates and let TeamViewer update itself within a week. Originally, I was hoping to use the TeamViewer's Policy management feature to push out a config change to enable weekly checks and to set "install new versions automatically" to All Versions. TeamViewer 9 doesn't support policies. Now I'm looking for alternatives.
My next option was to tweak registry settings (all the clients are Windows machines). I found: HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\TeamViewer\Version9\AutoUpdateMode which seems to correspond to the "Install new versions automatically" configuration option. I don't see a registry entry to change the "Check for new version" option. Does that option not exist or am I just missing it?
Anyone else have recommendation for the best way to get a bunch of TeamViewer 9 clients updated to 15? We do have the ability to run scripts on the clients, which I was hoping to use to tweak the registry and restart TeamViewer. I guess my final automated option would be to push a script that uninstalls 9 and then installs 15 via MSI.
    Hello @ndrake,
    Updating via the registry is not possible.
    We recommend uninstalling the clients and installing v15 via MSI, as you mentioned.
  • LCD_Media
    LCD_Media Posts: 2 ✭✭
    @ndrake
    Did you find another solution. Im having the same problem now
  • ndrake
    ndrake Posts: 3 ✭✭
    @LCD_Media We ended up going with a script that first uninstalls TV9 then installs TV15 and assigns to the account
