Why do some of my endpoints report that realtime scanning is disabled? How do I troubleshoot ?
4Lucy
Posts: 1 ✭
I'd like to know if there is a service that should be running. How do I verify that realtime is running?
The only way to be sure is to check the logs or download the eicar test file.
The logs are located in: C:\Program Files\ITbrain\AntiMalware\ITbrainAntiMalware_Logfile.log
Eicar test file: https://www.eicar.org/?page_id=3950 download and run a file.
If you have any issues with the wrong reporting please contact our support for further investigation: support.teamviewer.com
Have you tried our new Product: Malwarebytes Endpoint Protection (integrated) ?
Product Owner, Remote Management services.0
