BUG on Android App with Blackberry KEYone
I found a BUG.
The alt key on the physical keyboard simply doesn't work once a computer is being remotley controlled, dissalowing numbers to be inputted into text fields such as a password. It does however work before remotley controlling a pc, in the app itself. I'm using the latest version of the teamviewer app found In the playstore, with Android Nougat 7.1.1 running on the latest KEYone software released as of June 1 2017.
Any help or update on this would be greatly appreciated.
I tried with my KEYone. Press and hold down the "alt" key then the numbers. It runs.
Enjoy!1
