Copy and Paste (shortcuts) not working from MAC to Windows
Mikepade
Mikepade Posts: 3 ✭✭
hi there,
i am using a local MAC and am not able to use copy/paste shortcuts in Teamviewer from local to remote client?
Best Answers
  • Mikepade
    Answer ✓
    Never mind, found the solution, it's just using Control-X instead of Command-X on the Windows client!
  • Mikepade
    Answer ✓
    You copy with Command-C and paste with Control-V 🤣
  • Mikepade
    Answer ✓
    Hello @Mikepade,
    Wow! Thank you for sharing the solution! 🤩
    Therefore, what key combinations does a Mac user need to do when copy/pasting from Mac to Windows?
  • Mikepade
    Answer ✓
    Which makes total sense... 🤣
    Thanks for sharing 🤗
