Chrome on windows after Creators update drawing at all
jjmulenex
SO I noticed that some apps that use chrome as a viewport and even chrome do not draw there contents after the creators update. Attaching screenshots to show this. As a side note when view the remote computer directly the content in being renderd on the client with no problems.
this is how chrome loads now
Chrome loaded
and this is Edge loading fine. both have the same urls.
IE loaded
Hi jjmulenex,
Please deactivate the hardware accelaration in Chrome - after that it should be possible for TeamViewer to grab the screen. You can find the option in Crhome under "settings".
Julia
Find this helpful? Say thanks by clicking on the Thumbs Up button.0
