Any thoughts on how to fix this trouble?
Hi @mahisri
The device is assigned to your account or because the interface is not loading you were not able to do it? I am asking this because if is not assigned you can try like a quick fix if it is possible via the “Nearby contacts and devices” function for adding the device.
On some devices it seems that the Agent interface is not loading, we are aware and trying to fix it.
Tech Support IoT
Hi
Did you solve this problem ? I have the same and looking for solution.
