what's the correct version do install on macos high sierra?
Hi!
What's the correct version do install from teamviewer's site, to install on high sierra?
I downloaded the latest version (15, cannot install)
Then the version 14, cannot install
Then, the version 13, install but requires update, and the update cannot be installed!
Any clue?
  • Justin
    Hello @AleMac,
    Do you receive any error messages, while trying to install or update? If so, please provide me with a screenshot.
    macOS 10.13 (High Sierra) supports TeamViewer version 12 - 15.19.
    However, you can check out our list of supported operating systems by yourself:
    Justin
    German Community Moderator
  • lnnmlzen
    lnnmlzen Posts: 1
    edited August 2021
    you do not give an answer where to download version 15.19.
  • PpRosa
    PpRosa Posts: 2 ✭✭
    does such a link exist? i ran into the same situation, tried to update the teamviewer to receive a message that states the downloaded version does not support high sierra, and now i can not find any download link anywhere for v15.19.x
    thanks for any info!
  • vinhcomputer
    vinhcomputer Posts: 6 ✭✭
    I also need the link to version 15.19.x for my High Sierra. Could you please tell us users the link?
  • Justin
    We're currently implementing that you can download the latest supported version for your system directly and automatically.
    Meaning, the website will recognize what operating system you're trying to download TeamViewer on and will download the version for it accordingly.
    I'll keep you updated.
    Justin
