TeamViewer drops connection when getting to this stage
Hello, when attempting to connect to a machine using unattended access, I get to the above connection stage and the connection just drops. TeamViewer does not crash completely but I just get returned to the Computers and Contacts screen. This error does not occur to every machine (in fact most of my connections work OK), it just seems to affect a couple of them. I have made sure that TeamViewer is updated to the latest version but this doesn't help. I have also made sure that remote connections are allowed to the affected machines in the advanced system settings of Windows 10 (this fault is not exclusive to Windows 10 though).
I have been having these issues for a while and have worked around them using other RDP solutions but I can't find anything about this issue when searching on Google.
  • ChrisPye
    ChrisPye Posts: 8 ✭✭
    Does anyone have an answer for this?
  • ChrisPye
    For further information this user is also unable to connect to any other machines but with him, TeamViewer crashes completely whenever he attempts to connect.
  • ChrisPye
    edited September 2021
    The logs show the following when I try to connect to my colleague's machine. I've done my best to blank out and personal details.
    [log files removed per Community Guidelines]
  • ChrisPye
    Still looking for an answer for this problem
