Which app should I use on android mobile
Want to connect between my s21 and my wife's s21
  • Akiho
    Akiho Posts: 1,216 Moderator
    edited October 2021
    Hi @Squatch97402,
    Thank you for contacting TeamViewer Community.
    Please install Remote Control and Quick Support application.
    Remote Control is required for outgoing connection / on the supporting device, and Quick Support is used for incoming connection / on the supported device.
    For more information, please check the knowledge article - Connections From Mobile to Mobile Devices
    Hope this could help.
    Best Regards,
    Akiho
    Japanese Community Moderator / コミュニティモデレーター
