Control Alt Delete From iOS
David_Forman
Posts: 1 ✭
in Mobile
I have seen this question asked multiple times with no clear answer. Is there a way to send control alt delete from iOS version of teamviewer if my computer at home is locked?
Thank you very much for your time.
Yes, you can do this.
When being connected from your iOS device to the computer you see the menu bar on the right side of your iPhone. Clicking the "lightning" icon brings you to some quick actions. One of those is Ctrl + Alt + Del.
Hope that helps 🙌
Former Community Manager
Hi, on this note, how can I set up new quick actions like ctr+alt+del? Many thanks
