IPAD to windows 10 problem
Wuxin
I am using ipad with iOS 11 to connect windows client, it seems like ctrl+click, shift+click didnt work to select multi files or to select a range. and i cant use ctrl+/ to quick comment in atom(a code editor).
Hello.
I have an iPad with a bluetooth keyboard and a Swiftpoint mouse connected. I control a Windows mashine via the Teamviewer app. Works quite well. But. Is there a way to get the special keys like Shift, Ctrl, Windows-Key, Tabspace, from my bluetooth keyboard one by one through to the windows mashine?
Kind regards
same problem here.
Any solution?
