Ver 13 disconnects constantly!
rthawk
Even after setting the advanced time out for inactive session to 8 hours, it still disconnects within minutes!
1
About half of my connections end in the first minute or two. These are internal network computers that are set to connect regardless of internet. Very annoying.0
I'm having the same issue of TeamViewer disconnecting minutes after hooked .
let me know if you find an answer other wise i will drop TeamViewer and try [removed per Community Guidelines]
