Custom Black Screen
I have a custom black screen loaded on my remote system. I went and added the reg edit (see image). After rebooting the system and logging in with TeamViewer I still get the stock black screen. I'm guessing that I missed a step. Any help in getting the CustomBlackScreen to be used. Thanks.
    Answer ✓
    Hello @Code_Elevate97,
    That's a tricky one, as according to your screenshot, you did everything correctly...
    Did you try with a different image, just to check if maybe the image is broken?
    Answer ✓
  • Code_Elevate97
    Code_Elevate97 Posts: 4 ✭✭
    Should have thought of that on my own. I downloaded one of the samples from TeamViewer and it must not have saved correctly. I opened it in a photo editor and resaved it as a png and now it is working as it should. Thanks for the push in the right direction.
    @Code_Elevate97 very happy that I could help! ✌
    Hope to see you soon!
