TeamViewer option "dynamic password" system-wide
i try to create a deployment of TeamViewer Host 15 (15.22.3) as we want.
MSI package, unattended CLI installation and assignment works like a charm.
Only the configuration drives me crazy. Or better two special points:
  1. "DeactivatedDynamicPassword" under HKEY_CURRENT_USER
  2. absolute path to ".tvopt" file
Let's focus on the first point:
Is it or will it be possible to set these configuration for the whole system without GPO?
Thank you.
NeturiusGmbH
    Answer ✓
    Hello @NeturiusGmbH,
    Please correct me if not, but as far as I understand your post: you want to disable the random password on all your deployed clients.
    If this is the case, you can do this via TeamViewer policy:
    The parameter is called Password strength. Make sure to Enforce it as well, so it can't be enabled manually by the users.
    Did this answer the first point? 🤓
  • NeturiusGmbH
    NeturiusGmbH Posts: 3 ✭✭
    Yes, it does, thank you :)
    To the second:
    We start the MSI installation by a script where the parameters are given (API-Token, CustomConfig-ID, Assignment and Configuration).
    Before V15 we used the "importregfile=1" parameter. And now i try to switch to "settingsfile=".
    What i have tried so far:
    settingsfile="config.tvopt"
    settingsfile="/config.tvopt"
    settingsfile="%CD%\config.tvopt"
    settingsfile="%~dp0config.tvopt"
    Everytime, no settings (of the file) can be found in registry after installation finished. So, i guess, the file is not processed.
    A manual import of the tvopt file or an execution of the reg file does change the registry.
    The last test was:
    start /wait msiexec.exe /i "%~dp0TeamViewer_Host.msi" /qn APITOKEN=XXXXXXXXXXX CUSTOMCONFIGID=XXXX SETTINGSFILE="%~dp0TeamViewerSettings.tvopt" ASSIGNMENTOPTIONS="--reassign --alias %COMPUTERNAME% --group _Neu --grant-easy-access"
    Good 👍 let's tackle point 2 together now...
    If it's a local file, I recommend testing this:
    SETTINGSFILE="C:/my_settingsfile.tvopt"
    If it's a shared file, I recommend testing this:
    SETTINGSFILE="\\share\my_settingsfile.tvopt"
    ⚠Important is to make sure to use the exact name of the .tvopt file in your command line.
    Let me know how your testing goes!
  • NeturiusGmbH
    edited November 2021
    thanks for response. And, please apologize my late response.
    Nice, but this is just a reply from documentation. May i wasn't clear. If so please excuse.
    I neither have a local absolute path nor a smb-share.
    We use the potential of MSI and the internal workspace. So, my file is stored by MSI in a temporary folder, which will be cleaned up by MSI after installation.
    Why do i need an absolute path in a mass deployment where i can deliver an "all in one, simple double-click" package?
    The requirement kills this possibility :(
    Any workarounds?
    Thanks,
    Rene
    Unfortunately, I don't have any woraround to provide...
    I recommend opening a ticket via the link below:
    Open a ticket
    Our engineers will take a closer look at your issue...🔍👀
    JeanK
